Help with Factory Amp in a '96 SE
Post all your Nissan electronics, car audio and stereo questions here!
zacreth
Ok i found one topic on this but i don't think it helps me with my problem. Here's the senerio. I'm replacing all the speakers with a new head unit. I'm not using an amp because I have no money left for now. I will do that later.I have speakers with crossovers for the front component speakers. I want to bridge the connectors from the factory amp so i can use the existing wiring. I just need to know what wires from the the factory amp goes to. I'm hooking up the crossovers from the rear deck once i find out what wires go where. I will then run new wires from the rear deck to the front for tweeters and use the existing wires for the rear and front speakers.Any help would be great.Thx in advance guys.
onosqv
Car: '92 240sx Vert
factory amp is ****, bypass it. Find the amp, find the 2 wires going into it (pos & neg - same color as you hooked up the head unit to) & hook that up to the crossover.
Or run completely new wires. Then ditch the amp, weight savings & will sound better and less headaches.
