DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Wed Jun 14, 2006 4:50 am
i was losing more than a quart a day, and it was getting very expensive.
KA's have a real problem blowing the front main oil seal. this thing is like 7 bucks from nissan, and it resides under the crank pulley. if its leaking oil will be all over the area here.
you need a gear puller to get the pulley off, which you can rent for free at autozone. then after thats off there is a round rubber seal you will need to pry out with a seal puller or screwdriver.
i spent over 80 dollars on oil during my leak.... it was bad
