help with engine choice!!!!!!!!!!!
240sxApocalypse
Car: 1993 240sx
I have just gotten my 240sx and want to go with a engine swap no matter what (the engine has 140.xxx miles and i want to turbo the car)is the sr20 really that much better for track than the ka. I only have 5000 to spend so plz keep that in mind.
plainzwalker
I dont know if the SR is better for the track, but i can say that the SR is a night and day difference from the KA. It is way stronger then the stock KA, and to me a lot more fun to drive. Then again, I spent a little more then 5000 on the install since I got a fmic, exhaust, intake, bov and clutch.
partymonster 975
Car: 03 Maxima SE, 94 Corolla
well, IMO the SR is better for track then a 140k KA, but the swap will cost you more then 5k. You might want to consider a CA, cheaper then SR and with a few bolt ons which you can save for later on it will be just as fast as the SR.
karmakaze
Car: 98 240sx SE
they are both very good motors.
ka has more low end gruntsr has more top end
which do you want?
more things to consider: ka has a long stroke and the head is designed for NA. others will argue, but if your going to boost, i suggest a rebuild and a port.
if you don't want to put the work into it, the sr is easier to do right.
Blown240sx
Car: 1996 240sx
SR swap more exspenive than 5K wow then I must be cutting people deals by doing it for 5100.
