Craving4Boost wrote:fiznat i know you had a write up..but i gotta ask
how the hell do you take the tube off?! must i take the whole egr valve off? i cant fit anything in there! do you have to fin da big wrench to turn it? or will the 2 small bolts on top of the Tube do? im trying to do this without taking off the whole valve itself but its becoming very difficult...im trying to take it off so i can seal it off with a metal plate
Took me forever to take that off the first time, but the way I did it was to loosen the two 10mm bolts on the intake side, remove the stock catalytic converter & downpipe, loosen exhaust manifold, and finally fit a wrench in there to loosen the thing.
