gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Mon Aug 20, 2007 4:15 am
Don't worry about the angle of the lever itself. I just wanted to make sure that you understand all the obvious things should be checked out before moving stuff around.If the calipers, pads, and/or rotors need servicing, by all means take care of those things first.Next, when pulling up on the lever, how many clicks do you hear before you cant pull it up any further? Depending on who you ask, it should be between 6 and maybe 10.
Modified by gumby74 at 9:26 AM 8/20/2007
