Help with DVD Player
mtlm35x
Car: 2006 M35x
Just purchased a 2006 M35x and tried playing a DVD using the rear Screen and the screen is saying operation cannot be completed, tried a few different DVD's and all cam up the same way....any ideas...
mazz
Car: 2013 M37x Advance, Tech Touring and Premium, Black with Stone Interior
is the car in park with the emergency brake ondvd will not start without that
mtlm35x
Car: 2006 M35x
You tring to say my kids can't watch DVD's while the car is in motion? Sorry i'm lost and yes i did try in park and brake on
Modified by mtlm35x at 12:47 PM 12/24/2008
tigerclaws1318
Car: 2006 M45 Sport
lol was the dvd put it the right way?
mtlm35x
Car: 2006 M35x
funny....no i put the dvd in the gas tank
mazz
i am not trying to say jack i offer to help you did not like the answerthe other answer is read your manualhope i miss understood you and merry christmas
digiboy
Car: Infiniti M35x
No, if you have the rear screen opened you do not need to have the car parked with the emergency brake on. You only need the emergency brake on if you want to see the dvd on the front dash screen too (necessary if your kids aren't able to use the remote, sometimes).
Make sure you are inserting the dvd in the correct direction. Check the manual to verify orientation.
Assuming this is happening with an off the shelf DVD (not a copy), you will need to contact an Infiniti dealer. It should be under warranty unless something has been done to void it.
It sounds like a read error.
tkeskic
Car: 2006 M35x Premium with "Aero Package" + 2010 QX56 AWD 7 Seat/Premium + 2007 MB ML320cdi
DVD label facing passenger side into the center console DVD player (not glove box) will play the dvd with or without the rear dvd center DVD open, or the car in park/brake on; it will will however be limited to audio.
With the screen open in back it will play the video also on that screen, assuming that in the settings section (settings button on center front console), the rear DVD screen is set to display the movie, you can have it display map also (these settings the car has to be in park to change if I recall properly). You may also have to press the "disc" button on the dash until it shows that the DVD player is selected, not the CD changer.
I would suggest the owners manual would have best directions... but above may be enough to get you started;
if that is all what you have done; then its likely the unit is defective disc is dirty or a communications issues between devices, maybe someone did that DVD hack so they could play movies while driving (on front screen) and buggered it up and then sold it to you;tk
