Poyzinous »
https://forums.nicoclub.com/poyzinous-u125838.html
Mon Mar 02, 2009 12:52 pm
Its a common issue in first generation type one G35 sedans and coupes. Mostly coupes. The door lock actuator burns itself out some. And it barely works, sometimes it stops working. I've replaced like a hundred of them. More like 12 though. What I can tell you is that 60 of them have been replaced at my dealership in the last 3 years. And the drivers side is part number 80501-AM80A the passenger side is 80500-AM80A. They range from $200 to $300. Very likely the problem. They are not hard to replace, but it is better to let an experienced tech do it, since it is tricky to install, and you'll need a few uncommon tools.
