One of your cylinders is weak as hell (the one thats 120) a good running TT will have all numbers around 150 a rebuilt engine should have around 170, your engine is weak and needs to be rebuilt that's why your car is not pulling as hard as it should.canadian booster wrote:Ok I did compression tests.. 140, 130, 130, 135, 120, 130 ..
One coil pack had a crack in it so I could see the damn copper thread inside, one spark plug was so loose I didn't need a wrench to loosen it.. Bah!
So now the car is ticking.. Wtf? Tick tick tick
