OutToWinPAHC wrote:Yeah I am leaning toward the gasket as well. But check compression dry and wet first, then check the cat. You had a leak before the overheating, I would think gasket.
But, can cat just get clogged or just built up with s*** in just a matter of days? cuz im having the same problem... ive got nissam thermo, new water pump, new rad, new fan clutch, rad flush and im still overheating when i drive and im tired of pulling over... im going to buy a radiator fan and see if that helps, but i have changed everything cooling wise and its just frustrating... air bubbles cant be it cuz i bled it and went through rad for an hour... any solutions.
