stevenbang »
https://forums.nicoclub.com/stevenbang-u64333.html
Thu Jun 26, 2008 2:43 pm
so i started on a clutch/flywheel swap and i installed and mounted new flywheel, clutch and pressure plate and when i was going in to put the transmission back in, the input shaft slid in but it did not go all the way through so there is about an inch gap from the transmission to the engine. im sure i put the clutch, flywheel and pressure plate on correctly. any help guys? oh and i also lowered my engine a good few inches so theres more clearance from the firewall but still isnt going in all the way.
