Help With choosing parts for strut replacement
zach7685
Car: 2002 Infiniti QX4
2001.5 Nissan Pathfinder SE
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
1968 Mercedes 230-Sold
2005 VW beetle Convertible
2001.1 Nissan Pathfinder LE
Hey guys, I need advice on what parts I need to get for replacing my struts. I know I need to get OEM mounting parts but I don't know which ones I can keep and which to replace. I'm looking at the diagrams on Courtesy Parts Here Any help would be greatly appreciated. Looking at ordering the KYB G-2 struts from Rock Auto.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Also, do I need to get boots for the new struts? I have 226K on my front suspension.
blkqx4
Car: 1999 infinity qx4
First u will need some of the original parts. U can purchase the moog strut mounts from rockauto and the struts and also get the sway bar links while you are at it. The strut boots i suggest using the oem they snap in to the original parts u will be reusing. I got kyb boots and i had to cut and trim to fit u may do the same if u want they are cheaper. And i believe u are set.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
The Boots are completely degraded.
blkqx4
I mean buy oem from the nissan dealer easier fit
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Oh, ok thanks! Should the ball joins be ok is they haven't been replaced but look ok visibly?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
If there is no play at all when you grasp the wheel and try to wiggle it, you shouldn't need to replace the ball joint.
For mounting hardware, replace the upper and lower strut mount nuts as well as the center nut for the strut, and for the rear shocks you'll want the upper and lower mounting nuts.
Verycrisp
Car: 2014 Nissan Altima
2002 Infiniti QX4
2001 Nissan Maxima
blkqx4 and Towncivilian are right on. When I did mine I used the KYB struts in my 02 QX with 152K miles on them and they ride ggreat. It's been posted here, and I found it too late, but stay away from the KYB strut mount. Already had 1 go bad and the other is making noise. I changed 1 with moog and problem solved. Nothing worse than doing a job like that twice.
donald
Car: 2001 Infiniti QX4 (RIP, 2011)
2010 Pathfinder LE
Verycrisp wrote:blkqx4 and Towncivilian are right on. When I did mine I used the KYB struts in my 02 QX with 152K miles on them and they ride ggreat. It's been posted here, and I found it too late, but stay away from the KYB strut mount. Already had 1 go bad and the other is making noise. I changed 1 with moog and problem solved. Nothing worse than doing a job like that twice.
Echo on the KYB strut mount :ohno:
reference for the surprisingly poor quality on KYB strut mounts:
http://www.nissanpathfinders.net/forum/ ... ly-driver/
(see post4)
I also kept it simple, and went with OEM/Nissan/Infiniti dealership part for the strut mount.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Thanks guys for your help! Got all my parts on amazon and I couldn't be happier!
Replaced front Struts with KYB
Replaced the rear shocks with KYB Gas A Just great upgrade btw
Replaced the upper trailing arms (previously did lowers)
Replaced the front sway bar end links and bushings
Turned front rotors and replaced warn pads with ceramic
Had rear brake hardware adjusted
The Upper trailing arms.
Can you see a difference? :rotfl
The only issue I have now is a loud popping/clunking noise from the rear when it flexes (Like entering a steep driveway at an angle)
donald
2010 Pathfinder LE
zach7685 wrote: [...] The only issue I have now is a loud popping/clunking noise from the rear when it flexes (Like entering a steep driveway at an angle)
happens even at slow speed? or "normal" speed when going over bumps/driveways?
if at normal speed, I'd suggest checking the rear tire. Sometimes the rear tire can move about. Just make sure it's snug against the under-body.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
It's not the spare tire. It happens at slow speeds when the axle flexes
