help with check engine code
scottsnissan
Car: 1995 240 sx se
1995 240 sx se ob 1
Code that shows is 41 Cleared it and comes right back what can i do to remove the code And what is the part Where is it located and do u have a pic.
I ahve a cold air intkae hooked up and is that the prob?
PLease help with as many details as u can
savatoge
Car: 95 240SX SE KA-T
Code 41 is for your Intake Air Temperature Sensor. When your CAI was installed, your stock air filter box was removed...the Intake Air Temp Sensor was attached to it. You need to remove the sensor, cabling and socket from the air filter box and plug the socket back into your harness, making sure that the sensor is secure and not flapping around. That will stop your ECU from throwing the 41 code.
