loystock »
https://forums.nicoclub.com/loystock-u10145.html
Sun Jan 24, 2010 12:33 am
All of the fault codes point to a leak in the EVAP Canister Purge System. The problem may be as simple as a leaking Fuel Filler Cap. Open the filler cap and check its condition - crack/etc. Also check the filler neck and remove any corrosion, if applicable. Make sure the filler cap is an OEM one as after-market cap may not seat properly, causing the leak. It's possible that PO bought an after-market cap.
If the cap and filler neck are OK, then check all the tubings/hoses connected to the EVAP canister (located at the rear, driver side, between the fuel tank and filler cap. Look for crack, blockage or loose fitting, especially for the EVAP Canister Vent Control Valve, and fix as required. Make sure you take note of the connection of each tube before doing any disconnection (take picture, if possible).
If problem persisted, probable cause are as follows:-EVAP Canister Vent Control Valve-EVAP Control System Pressure Sensor & circuit-Water Separator-Vacuum Cut Valve
Refer to the FSM (Factory Service Manual) provided by 'tiger,' EC-564 (Engine Control System) and EC-531 for additional info.
