help with cd player install
Post all your Nissan electronics, car audio and stereo questions here!
94 Sentra-XE
Car: 94 sentra XE
Nissans jewish wiring has me =confused, these are the wires i have coming from my harness on my 95 240sx
2x red/yellow stripe2x orange/green stripe2x red/blue stripegreen with white stripegreen with red stripeblue
grey (split to clear, black and white)grey (split to clear, blue and pink)grey (split to clear, blue and pink)grey (clear, lt. green and purple)
now......what is what? i tried looking it up but didnt quite find what i needed, and someone on here posted a .ZIP of it but i dont have adobe on my computer, kthxbye
Modified by 94 Sentra-XE at 7:37 PM 3/1/2009
carmo
Car: 92 Accord, 90 Civic, 89 240sx
If you can, go to a junk yard and clip that connector off with about five inches of slack and then wire the connector back up in your car. You should be able to match up the wire colors. From there it's all plug-n-play for the exception of soldering up the adapter harness
94 Sentra-XE
Car: 94 sentra XE
was trying to avoid being anal raped by my junkyard, and none of them around here have s14's
carmo
I don't blame ya. I have a friend with a factory service manual. I'll see if I can get it.
94 Sentra-XE
Car: 94 sentra XE
carmo wrote:I don't blame ya. I have a friend with a factory service manual. I'll see if I can get it.
thanks man
Modified by 94 Sentra-XE at 4:29 PM 2/24/2009
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Here you go. 94 Sentra electrical
94 Sentra-XE
Car: 94 sentra XE
re read post.....S14!
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
Okay then.
94 Sentra-XE
Car: 94 sentra XE
thanks......still kinda confuzed haha doesnt seem like any of the colors in the FSM are on my harness
Hooked on 240
the converted wrote:Okay then.
Ill help this turd out when i go over there.....
94 Sentra-XE
Car: 94 sentra XE
can someone just tell me what the wires are, can someone just pull their deck out and look real quick?
zerepdivad
Car: '90 240sx . '02 Lexus IS300
get a multimeter, test wires, fix blown fuse or two, then cruise
94 Sentra-XE
Car: 94 sentra XE
what are you talking about
zerepdivad wrote:get a multimeter, test wires, fix blown fuse or two, then cruise
zerepdivad
buy a digital multimeter. Physically test your wires yourself it's not that complex for a simple radio install.
94 Sentra-XE
Car: 94 sentra XE
That isnt going to do anything.....the amps dont have power to power the speakers to test
zerepdivad
Ok well i'm sorry but you may as well take it to someone who knows what they're doing then.... hate to say it that way. but it doesn't look like you've put much effort into it at all since you won't even test the wires..
94 Sentra-XE
Car: 94 sentra XE
zerepdivad wrote:Ok well i'm sorry but you may as well take it to someone who knows what they're doing then.... hate to say it that way. but it doesn't look like you've put much effort into it at all since you won't even test the wires..
yeah thats right, can someone just help me out and post what that friggin wires are sence this is supposed to be a place for help
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
So if the wires aren't what they say that they are in the service manual, then you are going to have to test them and figure it out. If you don't have a multimeter or similar test equipment, your best bet is going to take it to a shop and have them do it for you. Have you bypassed you factory amp yet?
94 Sentra-XE
Car: 94 sentra XE
the converted wrote:So if the wires aren't what they say that they are in the service manual, then you are going to have to test them and figure it out. If you don't have a multimeter or similar test equipment, your best bet is going to take it to a shop and have them do it for you. Have you bypassed you factory amp yet?
lol why would i own a car without a tester, i still have the stock amps hooked up now every diagram i have looked at has said something different but using all of them and kind of combining what they all have said this is what i came up with (doubt its right cause i tried it and it dont work)
im assuming this car had double din so thats why there is 2x of all of the wires
(2x) red/yellow stripe= dimmer(2x) orange/green stripe= ?????(2x)red/ blue stripe = illumgreen/whie stripe= power ant triggergreen/ red stripe = ????blue= ignit
black and white wires= FRblue and pink wires = FLblue and pink wires = RRlt green and purple = LR
