Help with buying rear coilovers
Blue.s13
Car: 93 Blue hatch with Uras full kit
90k miles
Hey guys, my tires are rubbing and can't roll the fenders because one of the quarters has bondo in it and it will crack. So i'm trying to find rear coilovers for $200 or lower. Which brand is good? and is this a good idea to do this? Do they sell them just the rears by themselves?
Here's pics of the rubbing and everything.
body-filler-trimming-need-help-pics-t497536.html
Blue.s13
90k miles
Or do I need air shocks?
EnjoiNismo
Car: 93 240sx
Do you mean Rear Upper Control Arms so you can adjust the camber on your rear tires so you dont' rub anymore?
Blue.s13
90k miles
EnjoiNismo wrote:Do you mean Rear Upper Control Arms so you can adjust the camber on your rear tires so you dont' rub anymore?
Will I need a camber kit for this?
I'm not sure what those are..Will those work? My springs are way too bouncy. I have tenzo r gf2 springs with kyb gr2 struts/schocks
Blue.s13
90k miles
I think i'll be spending more money down the road on new tires wont i?
Won't running neg. camber wear out the tires really fast
Blue.s13
90k miles
bump
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
Blue.s13 wrote:I think i'll be spending more money down the road on new tires wont i?
not really. but a bad toe will eat up quickly than camber for sure. since there's bondo in your quarter panel, a narrower wheel is your best bet to not rub.
Blue.s13
90k miles
when you say narrower wheel are you talking about the side wall of the tire?
S14Kouki10
Car: 1997 240sx
you werent able to sand it down?
Blue.s13
90k miles
S14Kouki10 wrote:you werent able to sand it down?
I tried but I think theres metal down there too and i think it will rub either way until it gets a pull.
I didnt use a sand block. i used a grinder that was on a drill and it just ended up making it sharper under there
S14Kouki10
Car: 1997 240sx
its going to rub with coilovers too. most likely.
Blue.s13
90k miles
S14Kouki10 wrote:its going to rub with coilovers too. most likely.
It seriously sucks so bad! Almost every bump I hit, it rubs so bad and scares the *hit outta me
adrianfromthecastle
Car: 1992 Nissan 240sx
dang dude, it sounds like you still have a lot to learn about your rear suspension.
Anyways, from the looks of your sig (assuming that's your car), you probably just need a decent roll of your rear fenders. Pulling may not be necessary. With that being said, if youre careful enough, you may be able to roll it flat without affecting that bondo you were talking about.
You're tires already looked pretty stretched, and if you lower it more without touching your rear upper control arms (maybe even leave it stock?), it'll tuck in real nice with a good 1.5"-2" drop. The way the suspension geometry works is that if you push your rears down, the top of the wheels move inward... meaning that the tire and fender shouldn't touch
nifares240
i'm talking about the physical wheel. bondo around the quarter panel areas always create problems. I don't know how much bondo your car has.
Blue.s13
90k miles
My dad says he thinks that air shocks will stop the problem... But i haven't found any on the net for s13's
nifares240
I would just sell the car and get a cleaner one with no bondo.
night240
Car: Nissan 95
nifares240 wrote:I would just sell the car and get a cleaner one with no bondo.
^ i would go with his advice.
Blue.s13
90k miles
I put it up for sale locally but really don't want to sell her. 90k original miles right now and runs perfect.
I want a s13.5 or s14.5 with a SR so idk maybe i should just do that
Ajax
Car: 1991 240sx SE
2010 Mazda 5
Car looks pretty clean, shame to sell it just because your rubbing fender. Another, more expensive option would be over fenders or fender flares- just putting it out there.
Blue.s13
90k miles
Ajax wrote:Car looks pretty clean, shame to sell it just because your rubbing fender. Another, more expensive option would be over fenders or fender flares- just putting it out there.
Yeah man I really don't want to. I know i will regret it. I'm going to take it off and not sell. Just need to get with my body and have him do something for me
nifares240
I have a 190000 miles on my beater 240sx and it still runs excellent. all it needs some cheap tein tie rods set. don't feel bad about the 90k mileage. you can sell it to some kid for like 4500 judging from the looks and save up two more grand. then get yourself some nice sr swapped 240. the only down side is that you didn't do the work.
Blue.s13
90k miles
I'm keeping it.. I'll get my body guy to redo the bondo or something
