Absolushun wrote:since you're just trying to have one sub and one amp to power the sub, you just need a monoblock amp(1-ch amp and the preferred is a class d because its specific for a subwoofer). you can always have another amp for your fronts and rears for more clarity and a less of a chance of blowing them out during low notes. the direct definition for ohms is "electrical resistence to current", but in lamemans terms the lower the ohms(1 or 2)the harder the subwoofer is going to hit(SPL) but with the loss of SQ(sound quality).
WErrrrrr *screetching of tires*Wow, hold up, let's fix this real fast. Class D is not subwoofer specific, it just tends to be used only for subs due to the increased cost of high quality components required to make it suitable for full range use. Without getting into a profound physics based answer, of which is even outside my realm of explaining, suffice it to say, Class D amps can be used for anything so long as the manufacture specifies it.
1, 2 or 4 chan amps can be used for a single sub. It all depends on the impedence, in ohms, of the voicecoil (VC) and how many VC's it has. For example, if your speaker has a single 4ohm VC, you could take a two chan. amp, bridge it and double each channels output power, which is then combined to one. If the amp put out 100x2 at 4ohm, you will now get 400w to that one speaker. More on this later.
Ohms, power and sound quality. Two are mutually inclusive, one is has nothing to do with the other, can you tell me which one?
Let's discuss ohms. A speakers VC is wrapped in wire, of which has a certain amount of resistance. If it has a one ohm VC or dual eight ohm VC's, for all intensive purposes, it will sound exactly the same. As for power, if an amp is rated at 200w/chan at 4ohms, and you hook it up to a 2ohm speaker you should get 400w because the resistance is cut in half, so the power doubles. If the speaker is 8ohms, the resistance is doubled, so the power output by the amp gets cut in half to 100w.
As for what hits and what doesn't, it all depends on your enclosure and power available, assuming a quality sub driver is used.
*edit* fixed a couple important spelling errors, primarily a "not" to "now"
Modified by Looneybomber at 3:23 PM 7/10/2007
