Silvia2b »
https://forums.nicoclub.com/silvia2b-u2470.html
Thu Mar 20, 2003 4:50 am
O.k. so my problem was that after Nissan "adjusted" my E-brake, they just tightened the cable too far, I think the e-brake didn't work at all. they calimed it was problalby a bad cable. the next day I noticed one rotor on the drivers side was blue from heat. they tightend the cable so far that one of the calipers had the ratchet pulled past it's limit an locked. I put new rotors on within the next week and I checked under the car, inside the console to see the actual lever and ratcheing mechanism. I then re attatched the cable, because it looked fine, and I moved the lever back to it's normal position and externally it looks fine and seems to operate. but will not hold the weight of the car or slow the car down when it is applied while moving even slowly and the cable didn't seem to be stretched or anything. So I took it back to Nissan about 2000 miles later. Then claimed it was the calipers and quoted like $800.00 to fix it. It worked before they adjusted it. Now it doesn't and they cause the calipers to fail I believe. I bought some remanufactured calipers by Bendix, at Napa for $130, w/ $80 core charge I'm going to put one on tonight and do the other in the morning, bleed the sytem after flushing out all the dirty fluid and refill and try to see if that fixes it. Anybody have other suggestions to consider while doing the install?
