Help with brake job!
GreekM3
I am replacing the front brakes on my 89 240 (no abs). I took off the caliper and put the new brakes on but when I Tried to put the caliper back on it wouldn't fit because the piston in the caliper is too far out. How can I put the piston in the caliper back in so it will fit over the pads? Do I need to get a C-clamp? Any quick help would be appreciated...I need my car tommorow to drive to school!
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
Front brakes > c-clampRear brakes > Box tool found at autozone / discount, or long needle nose pliers, as they need to be turned / screwed in.
Former_240_s14
Car: 07 BMW 335i Coupe
I would just use a c clamp and a piece of wood for all four. Put a small piece of wood over your pistion so you do not do any damage to the pistion and just tighten the clamp to force the piston back into its hole. Goodluck
96_S14_SE
Um then you would have two busted rear pistons....... The rears need to be screwed in. Thats why there are notches in the piston face, and threads on the pistons insides.
Former_240_s14
Thanks for the correction, I was too lazy to read your post infront of me to see that the rear brakes needed the box tool. My bad.
thatguyin240
You know i changed my front pads last weekend also. All i did was apply presure to the piston gradually then it just magically worked :)
crappy pads bought at pepboys...
GreekM3
thatguyin240 wrote:You know i changed my front pads last weekend also. All i did was apply presure to the piston gradually then it just magically worked :)
:ylsuper
Hey the pads were only 18 bucks :) I didn't think I could put a price on my safety....but it turns out I could!!!
Thanks for the help..unfortunetely on the left side I stripped the ****ING bolt trying to get the caliper off and I bled the brakes on the right side wrong....no pressure now :( Do I have to bleed the whole system now?
thatguyin240
oh damnn Bleeding. I hate it.You will have to bleed it. Changing calipers i don't really thing you had to disconnect the brake line? I did the samething on my first time and man bleeding was a bi*ch.fortunely there is that new Bleeder Bolt at https://www.speedbleeder.commaybe try that out :)
another_nissan_owner
Car: installing car audio and collecting anything with NY Yankees on it.
this is the first car i have ever owned with rear disc brakes and it's simple as hell to put brakes on the car.
