Help with BELTS..
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
emuworld
Car: 03 350z
First of all I drive a Nissan 350z an '03.....
I've been having problems with the belts for a long time and tired of the same thing happenning pretty much///...
My AC belt keeps breaking or being shreded and sometimes it even takes out the alternator belt too....
I don't think it is a " not being tight enough " problem...
I also hear a click everytime I go from one gear to another in high revolutions....
Thank you so much in advance... Have a blessed day.
Mr. Z33
Car: 2003 Pearl White 350Z
It sounds to me like you just need to replace both of the drive belts. Mine is also an 03, and I just replaced them 2 weeks ago. Since it is one of the easiest reapirs to do, it should not take that long at all. I found it weird that mine needed to be replaced seeing that it only has 23k on it, but never the less they did.
aris_unlimited
Car: 1998 Ford F150 4.6L 5 speed. Edge programmer, 2" lift, 35" tires.
I also had to replace all my belts sooner than I thought necessary, but it did help out with the squealing problem I was having.
emuworld
Car: 03 350z
Guys thanks so much...
But my problem is that it has happened twice in a year... The Ac Belt shreddes and comes off and sometimes it takes the altenartor one with it....
So It keeps doing the same thing....
I drive fast i don't know if that's the reason why it does that...
Poyzinous
Car: 2004 G35x Premium 1976 Classic Red 36 inch #18 Radio Flyer Wagon...
Replace your pulleysPart Numbers 11925-AL50A11925-AG30A
Being too loose won't cause them to shred. Being incorrectly installed will.
BusyBadger
Car: '92 Nissan 240SX
'05 Nissan 350Z
'13 Nissan Juke
Check / fix your pulleys and then find some Power Enterprise belts.
Return to “350z / 370z Technical”
