Help with auto sohc kae to 5spd dohc kade swap!
Abstrakt02
Car: 1993 240sx Hatchback (front end silvia conversion)
I'm currently sourcing out the following parts for myAUTOMATIC SOHC to 5 speed DOHC
1) complete AND RUNNING with no MAJOR problems kade engine and 5 speed transmission! -5 speed transmission adapter plate and dust cover2) top and bottom wiring harnesses uncut3) complete 5 speed drive shaft4) shifter assembly (plate, lower boot, upper boot, finisher plate5) 5 speed cross member6) clutch master and slave cylinders as well as hardlines7) power steering reservoir, pump, and lines8 ) MAF9) 5 speed ecu
And I'm wondering if I'm missing anything or if I can reuse some of those stuff from my sohc!
any tips and hints would be greatly appreciated thanks!!
Full Street
Car: '90 240SX
I dont think your missing anything but I wouldnt use parts from a single-cam, just to be safe. Hope the swap goes nicely.
Abstrakt02
thanks
Abstrakt02
so I dont have to touch the fuse box or anything?? also people are talking about splicing the wiring harness but if I have the whole harness uncut and a dohc ecu cant I just replace the whole thing at once?
