pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sat Apr 09, 2005 4:25 pm
1987 PULSAR NX.SE with CA16DE engine1988 PULSAR NX.SE with CA18DE engine.
Flywheel, I know the flywheel from the ca18de is bigger in diameter and heavier than teh ca16de one, but both will plug in (definitely dont use the ca16de one as it has smaller clutch and won't hold the power), the ca18de will work, but not sure if it will work on a RWD configuration thought.
I am pretty sure you can get a spare DET flywheel from some members on this forum, I might have one, I have to double check on that, Also, Boost_Boy might have one.
Good luck,PULSAR GTRRafi
