Skeeg »
https://forums.nicoclub.com/skeeg-u73387.html
Wed Nov 28, 2007 4:14 pm
hey all, im wondering what power amp i will need for the subs im getting.
they are 2 alpine type R's dual 4ohm voice coils. rms for these are 600watts.
ok so my problem, most amps at 4ohms are soooo expensive for the power i need, i was looking at 2 channel amps.
but by ohms law, from my dad and i's understanding if we run the subs in parallel then the ohms will cut in half making it a 2ohm resistance.
this in effect, would only give me "one channel" i think, as there will be power going into the one sub, then passed to the other?
this is in fact 2ohms correct? and it would in fact be one channel? and thus if i were to have a 2 channel amp i would run it bridged? or would i just run a single channel and leave other empty to get the desired 2ohm rms i want?
i have confused myself over and over with this, and im sure none of this makes any sense..... so pls ask me questions to further explain because im unsure on how to be ahaha.
THANK U!!!
