300ZXttZMAN wrote:okk so you know how the on the z32 where the air filter is, there is that "Y" pipe (where the air filter hooks up to and then the plastic pipe splits to the right and the left) my car does not have the Y pipe it has an addapted filter that just mounts right up to the intake pipe... Could this cause my car not to be able to rev past 3500 rpm??? Has anyone else ran in to this "rev limit" problem??? does anyone else run their car this way without the "Y" pipe
I have changed all vacum lines
maf sensor
iac sensor
fuel filter
air filter
tps sensor
iac sensor
thanks for all the help
(my car is a 90 tt)
itsa300zx wrote:300ZXttZMAN wrote:okk so you know how the on the z32 where the air filter is, there is that "Y" pipe (where the air filter hooks up to and then the plastic pipe splits to the right and the left) my car does not have the Y pipe it has an addapted filter that just mounts right up to the intake pipe... Could this cause my car not to be able to rev past 3500 rpm??? Has anyone else ran in to this "rev limit" problem??? does anyone else run their car this way without the "Y" pipe
maf sensor
iac sensor
fuel filter
air filter
tps sensor
iac sensor
(my car is a 90 tt)
Where are you mounting the MAF if you do not have the Y connector? THe MAF need to measure the total airflow into both sides (Land R). THe way you describe, sound like you are only measuring flow on one side. A picture would help?
Can you find a used Y connector?
sounds like an issue with the MAF circuit. Or your base timing (set by the CAS)300ZXttZMAN wrote:see thats the wierdest thing im not getting any codes its like the shop may have messed up on routing the hoses becasue my car didnt do that before i brought it to them... so they are lookiing at it but still if anyone knows about what would be making it
"rev limit" let me know plzz..... i miss my z
Losing fuel pressure would cause a studder, but also cause detonation. May be tough to hear over the studdering, but listen for it as well.NolimitZ32 wrote:Gap is .044 and FPR sounds like it could be a culprit or maybe your fuel pump is dieing either way check your active fuel pressure as in hook up a gauge to the system and go drive around make sure you're not loosing fuel pressure at higher rpm
Correct, and a quick check to see if the regulator is working correctly is to disconnect the vacuum hose at idle. Should jump from 36ish PSI to 45ish PSI IIRC.NolimitZ32 wrote:did he check the fuel pressure at idle or under load, those are 2 very different conditions.
