That does work, the wife had it done, and they did the same thing, and autozone cant clear it, i guess its different or something.Shad0wXCalibur wrote:Try this. It worked perfectly for me when I installed my new deck.
FOUND A SOLUTION! As long as the airbag hasn't ACTUALLY been depolyed, this will reset the system.1.Turn the key from off to on.2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key to acc instantly.3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)4. Repeat steps 1-3 two more times until you have done the cycle three times.5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
After I completed step 4 and turned the ignition back on, the light quit flashing without the need for step 5 & 6
YES! THANK YOU! I changed my head unit this past week and took out the air bag connector (like how we're not supposed too).This solution also fixed the driver window from automatically coming up using the switch.thanks again!Shad0wXCalibur wrote:Try this. It worked perfectly for me when I installed my new deck.
Even if it did, it's an easy fix. Run the window down, then run it up with the button held for about 6-10 seconds after it's up and it'll work fine again.comsdude wrote:R U saying that doing the key sequence caused your driver's side window to not auto up anymore?
does the light come on during bulb check of the gauge cluster just before you start the vehicle? if so then it is working properly the light comes on during bulb check then turns off after a set amount of time. normal operation.ibogs wrote:Hi
I have the same problem. "no passenger light" stays off all the time. Any body idea how to fix it?
move around in the passenger seat it should light up for a few seconds.ibogs wrote:Hi
how can they sleep at night09VersaSedan wrote:I was in the same situation as stated in the original post! Had it for 2 days, ripped out the dash, installed a deck correctly, and bam, freaking flashing light! Nissan dealership said they'd have to hook it up to a laptop and scantool, etc. and it would take an HOUR to fix! Yeah right, this worked perfectly! Thanks!!!
