help with a ground on the s13 motor
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
I forgot were the little ground strap that plugs into the firewall just above the back of the motor goes.Do i bolt it on to the back of the head around were the heater hoses go,or does it bolt on to the valve cover?And this is on a 92 240 with a s13 redtop.Thanks for the help.
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
I believe it goes to the back of the valve cover, but I'm not 100% sure though. I don't think it would really make a difference as long as it makes good contact.
robbbby
I'd just put that small ground for the valvecover than run grounds with larger gauge wires for the block, cylinder head, intake manifold and whatever else you want.
pampadori
Car: 91 Nissan 240SX coupe
it goes on the back of the block. Shaun
VitaminT
Car: 93 240sx SE
The one I pulled recently was on the head I believe. I know I pulled the valve cover and is wasn't there and I am pretty sure it came out with the head.
180fan
Car: 89 fastback
the one that screws into the firewall is from the head.
9240sx
Ok,Thanks guys,Im going to put it on the head in one of those 12mm bolt holes.
