Larz »
https://forums.nicoclub.com/larz-u216291.html
Tue Jun 18, 2013 11:23 pm
That's a head-scratcher! I cannot think how the A/C problem could be caused by the filter change (I don't think you were saying that either). If the vents are not changing between recirculated air and outside air, even when the switch says it has .... that leads me to believe whatever makes those vents open and close to the outside has gone bad. If they work off a vaccuum line, maybe there is a loose vaccuum hose? If they work electronically, then it could be a loose connection of a bad module that can't tell the outside vent to close so that only air inside the cabin is circulated.
Sorry, mate that's all I could come up with.
