Help with a 95 to 98 motor swap
driftneil
Car: A pile of cars.
Hey there guys, it's Neil. I'm having a problem swapping engines, from a 95 to a 98 kade. The problem I'm running into is the (I belive) the vacume rail on the intake side. The motor I purchased had the line cut, so I'm stumped. Got a couple pics of the rail and hoses from it. Can anyone tell me where to run them to, or give me a link to figure it out myself? Any help is greatly appreciated! Thanks Nico, someone help me. Thanks for looking!
driftneil
Nevermind, I found a factory service man. Noe all I need to know is if I can delete the evap purge solenoid or is it manditory to have it?
xweav32
Car: 2011 Nissan Versa S 6spd (daily)
1995 Nissan 240SX SR20DET 5spd (fun car)
dude just put the 95 intake manifold on and use your 95 ecu and wiring harness
driftneil
Good call, but I assume I could just delete the evap solenoid. Because the 95 doesn't have it. So I should just be able to block the vac line up for it......I assume????Any comments?
driftneil
How hard is it to pull the mani??
xweav32
easy six bolts. if u usw the 95 mani all you have to do is put your 95 o2 sensor on and put the motor in. boom done no d!ck around
driftneil
Nice...Thanks alot man.
