zul8tr »
https://forums.nicoclub.com/zul8tr-u26979.html
Wed Sep 10, 2008 5:15 pm
My car does not overheat. The temp at the thermostat intake tube is 182F with an infra red temp gun. At the coolant temp sensor it is about 175F. Car has stock thermostst.
I replaced the coolant temp sensor and checked the ohms with a digital VOM in a heated pot of water before installing. All ohm readings in spec per the manual.
Engine has code 55 in the ECU
The fans operate at low speed and high speed.
Problem I am having is with car warmed up to normal *about 180F) with AC on the high speed fans come on when temps are as noted above about 180F. Per the service manual the high speed fans should not come on until 203F at the coolant temp sensor with car less than 50 mph and idle. What else can I check to resolve the high speed fans from coming at to low a temp? What about the relays could they be providing a complete circuit but not at the correct temp? How do you remove the plastic tops from each relay to check relay circuit?
Thanks
