firstq »
https://forums.nicoclub.com/firstq-u958.html
Sun Feb 15, 2004 3:52 pm
Thanks for y our help.
Are you sure the order is "Nut, bearing cover, washer, tensioner pulley, washer(s), spindle. "
I somehow remember " Nut, washer, bearing cover, tensioner pulley, washer(s), spindle. "
Can you or anyone else please confirm - this makes sense. Interestingly, the only way I could get the PS pulley to work (move freely once the centre nut is tightened) is by putting a washer in b/w pulley and the bearing cover.
If confirmed, I will need to redo all the 3 pulleys.
Thanks
