Spiffy240 wrote:i searched
so how would i wire 6 1/2 speakers into the front speaker mounts
Just like you would the 4x6's. Match your polarities and vowala, it's that easy and thus the reason why you couldn't find anything searching. It's probably never been asked before.
Spiffy240 wrote:yesterday i took off the doorpanel and took out the whole part where the stock 4x6 would go and i see the little wirings and circuit board that looks like a mini amp
but i have a question, do i do, b/c it looks like the rear speakers also connect to that miniamp, so do i have to rewire all the speakers?
Alright, I don't know Nissans, but if you're taking out the existing amp and wires, you will have to replace it with something. Sound logical? So yes you have to rewire them. You can either use an aftermarket headunit to power them or an amp.
IMO, I don't see why you'd need to take out the existing wires and amps. If you don't feel like spending big bucks on a new headunit and amp, just leave in what you have, change out the speakers and you're done.
You complain that the existing amps in the doors are located on the mouting brackets that need to be modified or removed. Simple, relocate the amp, fab up your own mounting brackets and you're done.
If you were in the Topeka area, I'd help you out with it...for a fee
