MisterH wrote:The relearn was a necessity after you swapped out the IACV, so do that first before replacing any more parts. Your situation represents a perfect justification for purchasing one of those Nissan Consult II knock-offs. ( I think Nissan Data scan is one of them though there are others like autoenginuity). For around $200 you would have the ability to do most of the dealer tests and automated diagnostic routines. This will save you lots of time and money if you intend to do most repairs yourself. FYI: you don't need to lift the car to replace the FP or regulator. Fuel pump is inside the gas tank and that's underneath the back seat. There are multiple videos on Youtube that cover the procedure, but I would deal with the relearn first. Good luck
@MisterH, do you have or know the instructions for doing the relearn?
The vehicle is not mine, and she needs it for work by tomorrow (rental getting too expensive) or else I would get the Consult II. I may just get one because it would be nice to have either way.
@Rockwood, I am pretty sure the fuel filter is on the correct way, I was having the issues before I changed it though. I just changed it for a miracle fix, no miracles for me lately...
Do you have the throttle relearn instructions as well? I have been looking on some threads trying to find one, but I only seem to be getting years 03-04 relearns and in their below comments it says that it differs from 2001
Thanks again,
Javin
