help with 240 headlights?
kraf
Car: sleepy s13 hatch
my headlights dont go up and down at the same time. the drivers side one comes up a little bit before the passenger one and goes down a little before the passenger one. does anyone know how to time the motors to go up and down at the same time or how to fix this problem?
thanks
kraf
come one somebodys gotta know somehting about this
2jz_jzx90
Car: 97 240sx for sale, 94 jzx90,
you should just be happy that you have working ones...
FRnIsmO
Car: 240sx fastback
im no pro but if you look around with others and the lazy/sleepy eyes you can see it's pritty hard to find perfectly balanced headlights...as a matter of fact, sometimes the way you make them sleepy can drain and ultimately kill the motor...not saying that you do have lazy eyes but i'm saying the motors do die out...bummer....how bad is it? just cosmetic?
KGB
Car: 1989 Nissan 240sx & 2007 Ninja 650r
This is what im thinking. Take a look at the motor of the lights. If you have a DMM (sorry im in wyotech and im getting used to the terminology) voltmeter, just do a voltage drop of the motor, see how much volts its getting/suppose to be getting. Also check and make sure that there is no unwanted resistance for the flow of electricity I.e. corrosion. Keep in mind it does find its ways into wires.
kraf
id say one gets almost half way up before the other does. i do have sleepy eyes. i just did it the cheap way because i dont really care if i can turn them on or not. you know, where you just cut the brown wire and double click the headlight button to make them go down. i was hopeing to get them to move at the same time so i dont have to turn the knobs on the motors to even them out every time i want sleepy eyes. but the motors were out of time before i did the sleepy eyes mod. i only did the mod yesterday and have had the car for a couple months and when i bought it the lights were out of time.
i dont have a volt meter or anything like that so i cant check them. any other suggestions on how to tweak them?
FRnIsmO
Car: 240sx fastback
yea dude, brown wire cutting kills your motor....dont use it anymore because your motor is dying....trust me and connect the wire again. http://www.nicoclub.com/articles.php?id=200234 btw
kraf
what you just showed me tells me to cut the brown wire though? my lights were out of time before i cut the brown wire anyways.
i just wanna get them back in time!
FRnIsmO
Car: 240sx fastback
omg! so sorry lol i did the brown wire thing b4 with this one but still had it saved. this is the right one dude http://www.nicoclub.com/articles.php?id ... xTech.com/
