Help with 2010 G37x brake pad replacement
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
dbaxRonin
Car: 2016 Infiniti Q50 Red Sport 400
2010 Infiniti G37x AWD Coupe (Traded in)
2001 Infiniti i30L (Traded in)
Hey all...just curious if there is a write up somewhere on changing brake pads for a 2010 G37x coupe. I found this how-to on doing it for the Sport Edition, but I just have the standard brakes, and it doesn't look like they are similar:
http://infinitig37.com/g37-change-brake-pads.html
I've only changed pads once before in my life on my old Pontiac GXP and I think that was as easy as it could get. I ordered some Hawk Yellow ceramics for my G37 from TunerzStore and would like to give her the ol' college try, but I would like some kind of reference to just be sure I am not missing anything. Am I going to have to remove the entire caliper, or is there going to be a pin/plate combo that will let me just slide them out and back in?
I appreciate any guidance. Thanks!
Hey dbax! The process is essentially identical. Although they look dissimilar, the rest is the same.
Here's another DIY article with calipers more similar to yours: diy-brake-pads-rotors-t558899.html
dbaxRonin
Thank you hitman! That looks a lot like my setup...that is exactly the kind of post/article I was looking for!
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
