patReily »
https://forums.nicoclub.com/patreily-u132423.html
Sat Apr 25, 2009 8:20 am
Hi all,I’m working on a 1992 Q45, 265,000 miles with a seized motor. I have 30+ years of auto repair experience. But today, I only do work for people down on their luck, who can’t afford to pay. Most have point-A to point-B car but one of the guys I help has a Q45 he driven for the last 2 years. I first worked on the car about 6 months ago when he began complaining of performance problems. Under the hood, it was obvious this car had seen a lot of work that was less than professional (broken connectors, missing bolts, bad patch work) attention. The TBS connector had failed so I cleaned the contacts and the car was back in action. Shortly after, the fuel pump failed and I replaced the pump. When I completed the job it was obvious that the engine was running rich and a little down on power but at 265K mile and no money you live with less than perfect.After a week, the owner told me that gas mileage was awful. I thought, It is a heavy car with a V8 motor but I took a look at it anyway. I thought maybe a fuel injector has failed open. When I removed the plenum, to my surprise, the #1 runner was filled with fuel. That must be 8oz! All the other runners look normal. I bought him an injector, mopped up the gas from the runner with a rag, dealt with more than a few bad hoses under the plenum and put it all back together. When I went to crank it, it didn’t go a full revolution before dull stopping sound and the starter would turn no more. I pulled the plugs, 4 were very rich, 3 were so so and the #1 plug looked brand new, out of the box ( well washed I assume). I’m guessing that #1 is seized. With the belts relaxed, I am unable to turn the crank, in either direction, with an 18 inch bar using moderate force. At this point, I am reluctant to use greater force before getting a little advice from resident gurus. Spotting through the plug holes I can see that #2 & #3 are near the top of the stroke, #4 & #5 near the bottom. None of them had standing fuel in them.For the less experienced: It is not the starter, torque converter, belt, etc. It’s a seized motor.With that as background, I’m open to suggestion. I think she may be dead but I’m hoping someone may have some sage advice. If not, my friend has a great donor / parts car for someone.Thanks,Pat
