HELP, Wiring for Starter and Alternator
skyline3489
Car: 95 Kouki Conversion 240sx (Sold)
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
16 Challenger Hellcat
im wiring my sr20 up and dont know where this wire goes, also when i cranked motor i just hear the starter clicking?
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
It looks like it is bundled with the alternator set of wires so it would be a ground. If it's like the redtop then there is a bolt that has like a 6 or 8 mm head on it that is just to the left (towards the driver side of the car) of the lead power wire of the alternator.
n240sxfnatic
Its a ground, make sure you started is grounded as well, or it wont start and just click like u say.
EnjoiNismo
Car: 93 240sx
Yeah its the ground for the alternator.
skyline3489
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
alright thanks guys, ya been alot of help to me
skyline3489
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
alright i just tried starting my engine again and all i heard was the start do quick clicking then i heard something go zooom like it was trying to shoot out, dont know the exact word how ud explain
hboninc19
ck ur battery. And enging grounds
skyline3489
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
i just tested the started and it works perfect so its not the solenoid so ima reinstall and see if itll work
skyline3489
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
ok i just installed the starter again now it makes the clicking noise over and over then does like a very low crank, then stops. is this cause im running the battery off jumper cables to the car?
skyline3489
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
k guessing it was because of me running off the jumper cables since i dropped to 4.5 volts when i crank engine over
Kalypso
n240sxfnatic wrote:Its a ground, make sure you started is grounded as well, or it wont start and just click like u say.
he's right. attached the ground wire from the Battery to the base of the block on the intake side.
skyline3489
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
i have the ground connected to the intake and battery tray
skyline3489
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
ok i tried starter again this time my engine was cranking over very slowley
CRyan
Car: 1997 Nissan 240SX
either A. bad connection or B. not a good battery. Mine was clicking once and not turning the motor over. I have to continue allowing it to click and click as i turn from ON to START position and eventually it decides to spin over.
But I would defiently get battery tested - might not be making the cranking amps you need. . .
EnjoiNismo
Car: 93 240sx
CRyan wrote:either A. bad connection or B. not a good battery. Mine was clicking once and not turning the motor over. I have to continue allowing it to click and click as i turn from ON to START position and eventually it decides to spin over.
My motor just kept clicking once, but when i tighten down the battery it turned over -__-'
skyline3489
93 FD Rx7 (Sold)
91 TII Rx7 (Sold)
72 240z Rb26
ight my guess is that since im waiting for my battery to be shipped i ran my old battery off jumper cables to the car, so Monday i get my new battery and then ill strap that baby down and hope it fully cranks over
