HELP: Will this S14 tire/rim combination work?
myfirstcarisa240yay
Car: 96' 240sx s14 Zenki
wondering if this combination of wheels and tires will fit my S14. i was thinking 19x10+20 in the rear, wrapped with 265/40-19, and 19X8.5+15 in the front wrapped in 235/40-19... i have stock suspension and camber.... i realize i may have to roll my fenders to avoid rubbing if i hit bumps and stuff, but will this combination generally fit the wheel well? i did a little measuring and calculating, it looks like it would fit fine to me, i just need extra opinion. im new to the silvia/240 scene being as this is the first car i've ever bought, and i made the mistake of buying cheap 18X8 with lo-pro tires that made my car look really bad.... so im looking for a better size, and after doing some research i came up with this combination.
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
your car will always look bad with stock suspension no matter how many sets of wheels you throw at it
myfirstcarisa240yay
Tyler wrote:your car will always look bad with stock suspension no matter how many sets of wheels you throw at it
thanks for the tip... but it still dosent answer my question.... :squint:
simmode1
Car: Red '95 S14
myfirstcarisa240yay wrote: im new to the silvia/240 scene being as this is the first car i've ever bought,
My opinion: Pick a path more traveled. Decently sized 18's are perfect on S14's. 19's can be difficult to pull off properly.
I'd say pick a setup that you like and try to come up with something similar:
http://www.rimtuck.com/thumbnails.php?v ... emodel=S14&
jeb1517
Car: 2013 Kia Optima
2015 Nissan 370Z
2005 Honda S2000
I don't think it fill fit in the front because the stock shock tower has a very wide base where the spring sits. I know for sure that's true for s13 and I believe a14 has similar suspension. Only one way to find out, though.... :biggrin:
Dittoz7
Car: 1997 2f0WtY SE!
BBs 18x9 18x9.5 265 front 295 rear tires
skunk2 suspension with tokiko shock
*Not my car
240lookis
Car: 1990 240sx hatch
buy coilovers and 18s.
if you buy those 19s and run them with stock suspension everyone will laugh at you.
adrianfromthecastle
Car: 1992 Nissan 240sx
D0NK?
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
Could be worse ...
Never understood that fascination. For real though, start with suspension and then make the tire/wheel fitment. Works out much better that way.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
scotty-2-forty wrote:Could be worse ...
:wtf2: I can't believe that s**t!
scotty-2-forty
You should see him drift! Hahaha ... sorry for the thread jack.
sx moneypit
1986 Toyota MR2
It would be on it's back like a dead cockroach. :woot:
E7-S14
Car: ess 14 foo!
I had 19s on my S14
19x8.5 +5ish
19x9.5+10ish
it fit great, I was slammed(bottomed out all 4 coilovers) but still had rubbing issues up front. on the outer and inner fender well. if you have stock struts, the 19 may not clear the bottom perch or the strut body itself, depending on what the offset is.
you will have to modify your inner fender well to have no rubbing problems at full lock.
and like someone said already.
the car will always look bad at stock ride height ESP with 19s.
with 19s you'll effectively be adding 2 or so inches of upwards height to your car. if you run stock suspension.
and not to mention 19s usually much heavier than stock 16s and most 18s. you WILL be slower.
but like i said, i did it, loved it. ditched them for 18s, now thinking of going 17 because of weight and rotational mass improvements. im also on coilovers.
NME-s12
Car: 1995 kioki s14 w/ s14 sr20det , 1986 s12 biuld in progress
I have to agree on the fact you will have rubbing issues :( sorry
And you should buy what you want but 18's Look the best (in my opinion and i own a s14) Although consider buying some cheap as s*** coilovers just to abuse during daily driving. I know a few people that run godspeed 500 dollar coilovers while street driving and then swap to Stance or tein ect once they hit the track. I know ill get bashed for this but for daily driving and bashing the s*** out of em with pot holes etc id just get some godspeed coilovers seriously.
simmode1
Car: Red '95 S14
E7-S14 wrote:but like i said, i did it, loved it. ditched them for 18s, now thinking of going 17 because of weight and rotational mass improvements. im also on coilovers.
Man, don't forget how much cheaper tires are for 17's rather then 18's!
