Stock height. And I plan on keeping it that waySanoSuKe wrote:They will fit. The bolt pattern is the same. As for tires, 245/35/19 should be beefy enough. Are you lowered at all? do you plan on lowering the car?
According to the link below they are 18x9 front and 19x10 rear with 30+mm offset. They are the 5 selection downSanoSuKe wrote:are you sure they're 18" front and 19" rear? double check your main post
It's just odd to me lol. You're not driving a vetteAlexN09 wrote:Why wouldn't it work? If the overall tire dimension was the same wouldn't that be okay?
