As far as my signature goes, don't be jealous I have more then one project. A mild failure happened on the RB, and its going back together, but I have bigger and better plans for the future, involving all of nissan's engines. And I plan on blowing up a lot of them to see where real limits are, not yo bro i made 800whp with a 3mm hg, yo guys have no idea wut ur talkin bout!!
Your fail gauge reads wrong because you don't know how to read it.
neo240sx wrote:
You are retarded sir! Stock coils are prone to failure. Anyone with a RB motor would agree. LS2 coils produce a much higher spark then even the supersparks or whatever brand. And perfect AFR's are 11.4:1 while under boost according to my egt gauge.
Good thing we already know about LSx coils. And "perfect" afrs vary from setup to setup, so keep that in mind. Cj has run lots of boost/HP through stock coils. That was in japan where its easier to get replacements, but here we can get them from q45's as well. How ever, more spark is always better.
neo240sx wrote:
This forum is supposed to be about help on topics or for research. I searched and found nothing about "stupidly thick HG's" so I gave it a shot and am posting my results. The 3mm head gasket works on my rb25 neo so far with no issues under boost. I'll try to make it to a local dyno for some tuning time but until then if you wanna hate and are in the charlotte area, come get some!
You have to actually put forth effort to find good info. Trying varying versions of what you want to find helps, and doing research off the forums. I suggest looking at detonation and why it happens, and "quench" in the combustion chambers and how it helps prevent it.
MAYBE, just MAYBE, you happened to throw together an engine that has "acceptable" quench. Builds like yours I call "a balance of garbage" where you have just enough stuff thrown together where it works "OK". But it will never have out standing results.
And don't worry about my VQ- It'll probably make way more power then your RB25 ever could, and do it cheaper and more reliable then what you have. But thats what happens when you do research and learn for your self. And maybe one day soon I will stop by and take you up on your challenge. At the track, any of your choosing.
~Alex
