Help" Where are the ID#s located on the car.....
lele
Car: infiniti 1997 J30t
Where are the numbers located to check for remote compatibility..have a 1997 J30t..Thanks....K
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
the 93+J30 and 94-96 Q45 and G20 remotes are the same. Just look for the last 3 digits of the FCCID to be xxxxx073 or 078
elwesso
2007 BMW M Coupe
BTW, you can always post up what your looking at to make sure its compatible, we can tell you!
lele
Is the ID# and VIN number the same..if not where is the FCC # located to check compatibility.. The remote I bought is not working and has different instructions on programming. something about emergency flashers flashing after taking the key out of ignition..and they don't flash. Is there some sort of relay that might be bad? thanks kerri
