andromeda wrote: i remember on my buddys jetta, and once on my old integra i just had a faulty plug wire and it would completely make the motor sound like crap(like a dump truck) and no acceleration. I dont know if you've ruled that out but maybe when its doing it you can check it. You may know how to check it, but if not, one at a time take the plug wires off and if it makes it run worse then put it back on. If it stays the same when you take one of them off, then theres the prob. Hope that makes sense(you prolly knew how to anyways but maybe its just something as simple as that.
Thanks for the help I will try it 2morrow. And yea it sounds EXACTLY like a dump truck, but then again I get a constant squeeling sound at 3k+ rpm also.
