Help what do you think?
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
So i was driving my 240 last night. I wasnt being hard on it and right when i got into boost my car hesitated. Then i babied it back hame and parked it.
One thing i noticed when i popped the hood it was blowing alot of white smoke out the exhaust.
Then i also noticed when i went for my tools, i had forgot to install my bkr7e spark plugs and the o2 sensor wasnt installed, I kno im stupid I forgot to hook the o2 sensor bac up.
So what do you guys think happened?
EfiniRX7
Car: 93 FD3S not going anywhere, 2003 E46 M3 traded, s14 sold, 2010 camaro sold, now another kouki s14, FD did go somewhere, Now a 535whp rotary Kouki s14
You might have hit a lean spot.
Lonismos14
Do you think that could have blown the motor. I was only going about ten-15 mph
biggie
If you didn't see high temps on the way home or hear any knocking, then you probably are ok.
Lonismos14
Whheeeewww No knocking or high temps just alot of white smoke.
biggie
Have you cranked it since you hooked up the O2 sensor? Still smoking?
Lonismos14
im still at work, but when i get off im going to put it on. If it is still smoking you think the motor is done for.
trackslut240
Car: 1993 Nissan 240SX
check compression, u might have blown the turbo seal too...?...easiest thing to do is check compression, guessing the problem is gonna give you sleepless nights. i know, i have been there.
