HELP what do i do about this?
Iball20
Car: 1991 240sx
blew the gasket then thinking i was going to just replace it but i was wrong!!!!
HELP please :ohno: :ohno: :confused:
Hijacker
Car: '92 240sx Convertible
'94 F-150
The block will need to be taken to a machine shop and will probably need to be bored out to clean that rust up. If you're not financially up to building the motor, you can nab a cheap one from someone and slap in there.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Since the motor has to come out, I would attempt to hone the cylinders and see if its just surface rust. im with him though^, los like it'd been sitting like that for a while rusting away.
Iball20
Car: 1991 240sx
So I couldn't just get some degreaser and wipe it out? I wasn't planning on taking the entire engine out. I just wanted to take the head off.
compactfean
daily
No way. Rings would never seal right without at least at bare minimum a good hone. I'm leaning toward boring because its possible a hone won't clean up that much rust. Minimum for that is new rings and hone (if the gone comes out good.)
Iball20
Car: 1991 240sx
I'm going to wipe it out then take a pic to see if the walls ate damaged. Because the stuff comes right off if I wipe with my finger
Hijacker
'94 F-150
It might come off, but with rust like that, you usually get pitting on the cylinder walls. If it's super light, a re-hone MIGHT do the job, but 9 times out of 10, the only way to get rid of surface pitting on the walls is boring.
Iball20
Car: 1991 240sx
Ok. I will be posting a pic of me whipping it off later
