thanks for your reply; it will help me finish the job.
the metal case is actually wraped around the pulley (back side) like a neckless.
i was even thinking about clipping it so i can get through without...
so i figured out what happen.
the night before, I removed the timing cover; broken plastic pieces everywhere.
i picked off all the pieces i saw but a sharp/small piece lodged between the water pump pulley and ribbed belt (cracked to hell already).
started the car thereby snapping the belt.
of course, i dont realize this until too late.
10 minutes into driving; loud muffler popping like bang followed by cloud of white smoke everywhere.
removed everything to find that the belt snapped and water pump cracked in two.
not the gasket; the housing (thick iron).
will post pics once i replace the pump/belts.
