roy23pim »
https://forums.nicoclub.com/roy23pim-u88633.html
Sat Sep 19, 2009 1:23 pm
Ok so today i go and turn on the car and it starts up but then the car starts shaking while idling and theres puffs of white smoke coming out of the muffler, not alot but enough to notice it .. so maybe i think its the spark plugs so i take them off and i see that the #1 is alittle wet and the #4 is heavily wet .. so i get a flashlight to look down to the piston and in the #4 piston i see alot of water on top the piston .. so i start freaking out n getting pissed lol and then i check the oil and the oil is like this light brownish color .. so i get in the car and crank it but i dont turn it on, well it wouldn't anyways because i have all the spark plugs off, so i just crank it and a whole lot of water flies out of the #4 piston cylinder.. and i had just filled up the radiator with water and after it was all empty so i know that water is getting in somehow .. what could of caused so much water to get inside the cylinder?
