Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Fri Sep 14, 2007 9:53 am
Chances are it's a blown headgasket. If you managed to crack the exhaust manifold, you must have had that motor running way hot. The head probably was warped, which in turn led to the headgasket blowing out. My recommendation to you is to take the head off, take it to a shop and have them check for warping.
And since the block is aluminum too, take it in with the head and have them check the deck for warping as well.
