help w wheels/xxr 526
All things Altima Coupe.
Jlor1002
Car: '11 Altima Coupe 3.5SR
Has anyone seen the xxr 526 on our car? I'm thinking of getting 18x9 in chromium black. My car is silver car, tints 5% rear 20% on sides. While I'm on the road for work my car is currently at the shop for eibach (I posted a few wks ago about lowering for bad roads, coils vs springs...I was talked into springs), RL y-pipe, and shift kit install. I was thinking tire size 245/40?
Anyone have any thoughts about how this set up will look? There are two different offsets availabe - +25 or +35. what size are the stock 18s? I've been searching and think 18x7.5 +38? According to offset calculator w a 18x9 +35 I get 22mm extended vs factory. Is this too far out there?? Will these fit? I have NO clue what would work better, or at all, +25 or +35?? Thanks for any help.
pepesilvia
Car: 96 S14
this car has 19X9.5 +45.... with 255 tires. this seems to fit.... yur best bet would be to go with the most positive offset (+35) and then buy spacers to make it look better... sorry i couldn't be more help
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
Do +35 and bump them out with spacers to get the desired look!
Jlor1002
PERFECT! Thanks for the help fellas.
