For that amount of power, as lennon said, it'll be way easier to use a bottom-mount turbo.
I'd suggest one of the following:GT28RS "disco potato" - maxes out at about 320hp with cames and intake manifoldGT2871R - like the GT28RS, but with the NS111 compressor wheel (same as the GT series turbos). should max out at 350hp or so with cams, good tune, etc.GT25R - the smaller AR (.64) should be able to hit 350hp without cams, higher with cams, manifold, etc. The bigger AR (.82, or .86, i can't remember) will max out around 400hp after cams, etc.
All the horsepower figures I listed are RWHP. If you've got any more questions, let me know. I'm aiming for 350rwhp on pump gas, so I'm in the process of making all these decisions
~matt
