I have 22.5 at idle and 27 when I let off the gas. The diapharm looks ok. but the actual shaft assembly has a little bit of play I think this is where the problem is.S14tat wrote:it depends on how stiff the spring is set at. generally most atmosphereic vented blow off valves. so it should stay closed at 22-23 inches of vac. try to losen the adjuster screw and use the vacuum pump to see if it opens. i'm guessing it should set to open at around 25 inches of vacuum.
