bryanmenard »
https://forums.nicoclub.com/bryanmenard-u3714.html
Sun Aug 21, 2005 8:12 pm
AM Radio is difficult to troubleshoot. Even without the car, it's going to be vulnerable to interference from a lot of areas...everything from sunspots to clouds, lightning, and a vehicle's engine and electronics. And, on the same token, AM has superior range to FM, but with lower sound quality.
I don't know what kind of car this friend has, but it's been my experience that AM works best in vehicles with an external antenna and not a window antenna.
Keep in mind, also that the Nissan Diversity System (power antenna and window antenna) works ONLY on FM...in AM, it pulls only from the power antenna...hence the name "FM DIVERSITY SYSTEM."
Did you consider that the motion of the vehicle could be causing the problem? A vehicle is an inherently poor location to receive any analog signal...moving constantly. AM is worse than FM on this.
If the car has just a window antenna, he's probably out of luck. If the guy is hardcore about shielding his AM signal, he should go with an aftermarket, external antenna, run directly to the radio with EMI shielded cable.
