hob »
https://forums.nicoclub.com/hob-u14325.html
Tue May 11, 2004 4:08 am
I had already pulled the ecu and got codes 34, and 35. I reset the ecu and it promply came back on. I repulled the codes and got the same 34, 35. I am not sure where to start w/ the code 35, as everywhere I look it says for Cal. models only.
The car seems to be running well, it does bog down between 1,500 and 2,000 rpm some times, but I figured that was a fuel prob. or the knock sensor retarding my timing??
Thanks again for all your help....
